Is there a way to create a dashboard that joins Jira tickets from two different systems
Kevin Wu
December 13, 2022
I have two Jira instances at work, is there a way to create a single dashboard that pulls Jira tickets from both systems into one view?
Aron Gombas _Midori_
In addition to the 2 ideas (both are great!), you may want to check out this app. It is trying to give you a "bridge" that spans multiple Jira instances...
See: https://marketplace.atlassian.com/apps/1217469/watchtower-integrate-issues-from-multiple-jira-and-trello?hosting=cloud&tab=overview
Alex Koxaras -Relational-
Hi @Kevin Wu
In addition to what @Sushant Verma said, you could get a syncing app, which will allow you to sync issues between your jira instances. In this case you would have a uni or bidirectional syncing of issues. After that you could use Jira native dashboard's capabilities to do your work.
For the syncing process you can use Exalate or Backbone Issue Sync for Jira.
Sushant Verma
Hi @Kevin Wu
You can build such dashboards in the external tools, like Power BI  / Tableau / BigQuery etc.
In this case you'll be able to fetch data from both Jira instances and combine and transform it however you need., in this case you'll need the app such as Power BI Connector for Jira.
Sushant Verma
