I need to implement 3 -4 levels of hierarchy in field where the content of sub-field will change based on top field selection
amit.kakkar@arm.com Hi,
There is the Cascading List field, but this only allows two levels of hierarchy, so you could only have list a,b,c with a sub-list of a.1,a.2..., b.1,b.2.... etc. based off your first answer. There is no built-in option to have more than these two levels of hierarchy, but there may be an add-on which can help with this
I am aware of 2 level of hierarchy but i need more.
Can you suggest which add-on can help.
amit.kakkar@arm.com
There is this add-on for server/data centre https://marketplace.atlassian.com/apps/5008/multi-level-cascading-select?hosting=server&tab=overview
I'm not sure about cloud, however
