Is there a way to create quick links to the System Dashboard?
Shreena Patel
Is there a way to create quick links on the System Dashboard? Not Administration quick links but links to help users go to certain pages within the system. It is not listed as a gadget to select from.
Wilhelm Krüger
July 31, 2012
Hi there,
if you want to create some quick links you could use the "introduction" gadget which is normally presented on the default dashboard.
To change the text you have to go to Administration -> "System" -> "General configuration"
You are allowed to use some HTML code, so you should be able to embed links.
