Hi! I am new to Jira, and I have been exploring this awesome software. My client wants me to create template on each project. Is that possible? I have 8 or 10 projects at hand and He wants to create template for each project.
Thanks!
Ed
Hi @eda_dellaban ,
Creat template on each project means create new project and share settings with an existing project or set different IssueType, workflow, etc. for each project?
It's not possible to create project templates in Jira.
Do you want to use that template to create new projects? You may use to create projects using shared config as mentioned in the below doc.
