Is there a way to create templates for issues?
Katie O'Dowd April 4, 2018
For example, if I have a checklist/template for communications, is there anyway to automatically add that to relevant issues?
Jack Hunter _HeroCoders_
Hello Katie,
You can also consider adding Checklist to your issues (in the form of ToDo list).
My company provides Issue Checklist app for Jira Cloud that solves the case you are asking for.
It allows users to set a default Checklist template, so every new issue in the project gets default checklist applied at the time the issue is created.
It is also possible to block issue transition (e.g., Resolve) if not all Checklist items are completed.
Along with many other features, it allows teams to solve other problems and improve the workflow.
I'm happy to answer all the questions and give more details.
Jack
Alexey Matveev
April 4, 2018
Kindly have a look at the Issue Templates for Jira plugin:
https://marketplace.atlassian.com/plugins/com.intenso.jira.issue-templates/cloud/overview
You can write your own plugin, or use ScriptRunner or PowerScripts. But you would need to write code in this case.
