In some cases we open test issues, whether tasks, bugs, epics or even user stories.
To examine processes, and other elements within.
We don't want them pea as done closed or whatever. Can it be deleted? Permanently?
Yes, if you mean you accidentally open an issue and you want to delete that, you can.
You would have to have the "Delete Issue Permission" configured in the Permission Schema used by that project.
Though I'm not quite sure why you would have to do that often?
Maybe you mean, mark the issue as somewhat not active? You could just use a new workflow status.
Best Regards
