Is there a way to export Logged-work? (Jira Cloud)
André Lindner
August 17, 2016
We want to export the logged work from JIRA to Excel, as input for a management report. So basically: Can we export per User, the Logged work Time per issue?
Rui Rodrigues
November 18, 2016
You can export issues to Excel using Xporter for JIRA. It allows you to create custom documents.
You can select all issues that you want to get the worklogs printed.
Take a look.
Rui Rodrigues.
André Lindner
November 20, 2016
Thanks for your reaction Rui. We have already resolved the issue via a Time-sheet plugin.
Rui Rodrigues
November 20, 2016
You're welcome. Take a look on Xporter add-on, maybe it will be useful for you.
Thank you.
Rui Rodrigues.
