Is there a way to filter saved filters? I'm needing to find which ones use a certain issue type.
Andrew Satterwhite March 28, 2022
Another way of looking at it, is can I export all of my saved filters in a format that is searchable? This would be comparable to the automations export into a JSON, and then I can look for issuetype = X,Y,Z
Bill Sheboy
March 28, 2022
Hi @Andrew Satterwhite
If these are your owned filters, you could use the REST API to get the list as JSON.  One of the fields is the JQL of the filter.  In a browser please try
myJiraUrl/rest/api/2/filter/my
Here is the documentation on that method:
https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/filter-getMyFilters
Alexander Bondarev
March 28, 2022
Hi @Andrew Satterwhite !
Welcome to the Community!
It sounds like a great feature, but it is impossible now =(
Ok. Thanks Alexander. At least I know I can stop chasing this!
AMIT GULATI
@Andrew Satterwhite How are your filters named? e.g. in our case we have names such "Stories in Current Sprint", " Features in Current PI" and there is an option to search the text in the name.
Great question Amit. Unfortunately, the issue types I'm looking for do not show up in the name of the filter.
