My team uses bitbucket for everything, including the issue tracker. Lately we started to develop some scrum techniques and where thinking of using jira.
I was surprised when the integration beetween jira and bitbucket didn't bring the issues. I tried getting them from Json export but had no success at all. I only need a easy way to bring the bitbucket issues to jira, this is really a dealbreaker for us. If there is no option we can't migrate to jira.
I think this article can help you with what you're looking for https://confluence.atlassian.com/bitbucket/export-or-import-issue-data-330797432.html
I already tried exporting the issues from bitbucket and importing on a new Jira Project, but I won't read the JSON file even after I changed it following Jira recommendation.
the json file you can convert to csv and import that to the jira for you to create your incidecia if it is not that the Json file. I think this is gonna help you.
Thank you, converting the JSON file to CSV partially worked(There where some data losses)
Hi, just in case, I leave you the documentation of how to import CSV to JIRA
