Is there a way to quickly change issue priority from a Kanban board?
Lee Butts March 23, 2015
We have our kanban in swimlanes based on epics and want a way to quickly change priority. The only I can find is by having to edit the issues (either one at a time or with "bulk change"). Is there any other way to add priority to the detail view so that it can be quickly changed?
Boris Berenberg
March 23, 2015
I don't think that there is any way to do this. You could add the field to the card, but I don't believe you will be able to inline edit it.
How can I add priority to the detail view on the right hand side?
Boris Berenberg
March 23, 2015
Lee Butts March 24, 2015
Thanks Boris, sadly Priority is not available to add as a field for some reason
