×Just as the subject, I didn't find the related fields either in workflow validator or in field configuration. I want to know how to set it as required. Thank you.
Hi @Jason Liu ,
This is an ambiguous question, you need to be specific.
for example:
1. Workload is required when transition Issues
2. Workload must be filled in every working day
3. Workload is required when creating a issue
4. Workload of some special status is required
