I'd like to see how the data in the Jira Plan could be captured before the tickets included in this Plan get changed outside of the Plan.
In the Jira Premium Plans you can see the changes that will be made to the issues before applying them. To do this, click on the Review changes option and you will see all the changes that will be made and apply them if you want to.
You can find more information here.
I hope this has been helpful, best regards!
You can use the save Views Feature
https://support.atlassian.com/jira-software-cloud/docs/save-a-new-view-in-advanced-roadmaps/
