×I'd love to be able to see issues in a filter where the Assignee has not updated the ticket within a certain number of days (e.g. within the last 3 days).
The updated date field isn't enough because if the ticket creator chases with a comment, then the updated date is of course also updated to todays date again, even though the assignee has not been active on this ticket.
Hi @Craig Pringle -- Welcome to the Atlassian Community!
To dynamically do what you ask about comparing an issue field (Assignee) to the issue change history, you are going to need to purchase a marketplace addon for JQL. Or...
As a work-around, you could add a custom field (e.g. LastUpdatedByAssignee) and an automation rule to set the field whenever the assignee changes the issue. For example:
You would then be able to query on the custom field as you note, checking for no/stale updates:
project = myProject
AND (LastUpdatedByAssignee <= startOfDay(-3) OR LastUpdatedByAssignee IS EMPTY)
AND statusCategory = "In Progress"
Hi Craig - Welcome to the Atlassian Community!
Maybe try: Project = ABC and updatedDate <= startOfDay(-3) and status = "In Progress"
Obviously, you would want to change the status value to whatever value you use in your workflow, and same with Project.
hello, @Craig Pringle
You can now use the updatedby() JQL function to get this information:
I hope this can be useful for you.
If you need more support about it, please tell us.
Many thanks for your speedy response @Jose Luis Gaitan
Is there a way to move away from having updatedby(user) and using a generic updatedby(assignee).
The use case is really that we want to track which issues have been sitting with an assignee for 3+ days without having been updated at all.
Somewhere in the query I guess we'd need to stress that the assignee was since 3 days the assignee and the assignee only hasn't updated the ticket in that same timeframe.
Craig
Hi Jose, did you solved this?
