×There is no obvious Plans download function in Advanced Roadmaps for Jira Cloud.
You can pull in the plan to Confluence with iframe, but it does not export.
Any ideas?
Hello @Angela Boston ,
Not yet, the export to CSV option in the new interface is currently only on the Server version of Advanced Roadmaps.
If it is critical to have the export option you would need to Disable improved interface and revert to the Live plan view which has exporting options avaliable in the reporting section of the interface, covered in the Live plan documentation here:
We are tracking implementation of this feature for the cloud version of the new interface at the following feature request, please make sure to add a vote to show your interest in implementation:
Earl
I see some data can be exported
https://confluence.atlassian.com/jiraportfolioserver/exporting-reports-to-csv-829825445.html
