Is there an easy way to run reports to capture issues raised over a number of years
ryan o_sullivan December 15, 2017
The canned reports expect usage of a default workflow which  is not valid for our usage
I need a to create a report of customer reported issues over the last 5 years , broken down by year , product and priority
Currently I am creating queries and running each  of them seperately
Is there an easier way ?
Example below , doing this is ok once but then breaking each  down by by product and priority is labour intensive
issuetype = Bug and createdDate  >= "2016/01/01"  and createdDate  <= "2016/12/31"  AND  status changed to (Closed, Implemented,verification)DURING ("2016/01/01","2016/12/31") and "Salesforce Case Reference" is not EMPTY"
Janis Plume (eazyBI)
December 18, 2017
Hi Ryan,
You can check the possible solutions of how to create such reports in the demo account of eazyBI add-on for Jira. Please, find here the dashboard of several report examples of how the issue counts can be reported across different dimensions. You can also have your Jira custom fields as report dimension.
Please, feel free to contact eazyBI support if you have further questions.
Best regards,
Janis Plume, eazyBI support
ryan o_sullivan December 18, 2017
Thanks Janis , I will  have a look at this for sure
Aron Gombas _Midori_
It sounds like a prototypical problem that can be solved with a regular pivot table report.
You can create those with Better Excel Plugin (samples) in Excel or with EasyBI in the web.
jira-created-vs-resolved-pivot-chart
Thanks Aron
I will  definitely investigate these , for now i hand craft the data sheets in excel . it took a day to  do it across products and priorities
