×Is there any way to allow for a preview of the issue without leaving the Jira filter ?
I am looking for behavior similar to Kanban board.
Thanks Walter ! I do not think that is same as Preview option in Kanban board.
Hi @Ashok Chotai,
Not sure what filter you are referring to. But if your question is about the issues list or the filter results in Filters > View all issues, there is a toggle that allows you to switch between list and detail view:
Detail view shows the search results on the left hand side of your screen and the full issue preview of the selected issue right next to it.
Hope this helps!
