Is it possible to execute JQL query from python script and get the result in a xml or character delimited format.
Urmimala
(NagraVision)
Use the jira-python library:
https://jira.readthedocs.io/en/master/examples.html#searching
Hello @Urmimala Biswal
Can you clarify for which purposes you need a JQL function in Python?
I'll try to help you when I get to know it.
Best regards, Mariana
from jira import JIRA
USER = 'you@yourdomain.com'
API_TOKEN ='<api token>'
options = {"server": "https://yourdomain.atlassian.net"}
jira = JIRA(options, basic_auth=(USER, API_TOKEN))
query = """
project = "MVP"
AND status = "Development done"
AND issuetype = Subtask
ORDER BY lastViewed DESC
my_jql = jira.search_issues(query)
for issue in my_jql:
print (issue.key)
print (issue.fields.customfield_10233)
#projects = jira.projects()
#for project in projects:
# print (project.key)
# All fields on a ticket
#ticket = 'TICKET-653'
#issue = jira.issue(ticket)
#for field_name in issue.raw['fields']:
# print ("Field:", field_name, "Value:", issue.raw['fields'][field_name])
#summary = issue.fields.summary
#print('ticket: ', ticket, summary)
Yes - use the search REST API. Also, requests is a good client library which you can use in Python to execute the REST call.
Validate your expertise in managing Jira Service Projects for Cloud. Master configuration, optimize workflows, and manage users seamlessly. Earn global 🗺️ recognition and advance your career as a trusted Jira Service management expert.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
