Is there any way to export a Jira project?
nhuynh
February 2, 2021
Hello everyone!
I am trying to export a JIRA Project from one JIRA instance and import that export file into my production environment.
I am wondering if this is possible? If there is a certain tool that I need to use? Keep in mind, this is cloud to cloud instances.
Kate Kabir
February 2, 2021
Hi Nhuynh
Thank you for the question.
Unfortunately we don't have a pre-made script for this but this endpoint is the one you would want to use: https://developer.atlassian.com/cloud/jira/platform/rest/v3/?utm_source=%2Fcloud%2Fjira%2Fplatform%2Frest%2F&utm_medium=302#api-rest-api-3-role-get
Thank You.
Kate
Stuart Capel - London
Hi @nhuynh
Yes it's possible: https://support.atlassian.com/jira-cloud-administration/docs/import-and-export-your-data-to-and-from-jira-cloud/
You have a few options and they are covered in the documentation.
