Is there any way to modify stories order in "Issue in feature" session in Epic issuetype?
satyanarayana.singamsetti
When we create epic and couple of stories under the Epic, when we open Epic and scrool down to Issues in feature session, we can see all stories linked to it.
is there any way we can to modify "Issues in feature"
1. Re-order stories in order of priority
2. Add version column and priority in "Issues in feature"
Please let me know if it's possible to make changes.
Satya
Thorsten Letschert _Decadis AG_
Hi @satyanarayana_singamsetti ,
The order should be editable via the "Advanced Settings" (%yourBaseURL%/secure/admin/AdvancedApplicationProperties.jspa) - scroll down to the jira.view.issue.links.sort.order property there.
Customizing columns is not available afaik. There are several closed tickets over time, e.g. https://jira.atlassian.com/browse/JRASERVER-25151, and I assume that the recommendation of "Issue Matrix" as an additional app is still valid.
Greetings from Germany,
Thorsten
Hannes Obweger - JXL for Jira
Hi @satyanarayana_singamsetti,
as already suggested, adding columns isn't currently possible - however if you're open to solutions from the Atlassian Marketplace, you should get pretty close; see e.g. this thread for possible directions forward.
Best, Hannes
SERVER
VERSION
9.12.15
