Is there way to dispaly confluence space link in project summary
KS
February 27, 2013
When I create project in Jira, a new space is created in Confluence and Application link is added to the project. Is there way to display link to that Confluence space on project summary page,?
Bruno Rosa
February 28, 2013
Hey Kirill, unfortunately there is no way to display it automatically. However, if you wish, you can manually add a description in the project - with its corresponding space URL - so that whenever you enter in the Project Summary page, you'll see the direct link to its corresponding space (for instance, image below):
Hope it helps!
Bruno Rosa
