Issue - Attachments two sections after update to Jira 8.3.1
Greg Drazek August 5, 2019
After update jira (7->8.3.1) I have two sections Attachments in issueJira_Attachments.png
Scott McDonald
Hello -
I found the same behavior to be true when having Zephyr installed (didn't matter the browser). Once I disabled the plugin, the dual attachments went away.
The vendor is aware and has been able to duplicate the issue.  They are working on a fix but don't have a timeline to when it will be resolved...
Adam Wride
August 14, 2019
@Scott McDonald - thanks for sharing - hopefully they'll fix soon.
I verified that disabling Zephyr fixes the issue.
Petr Vaníček
August 5, 2019
is this behaviour only for your user or also for someone else? We have 8.3.1 on our test env and without that problem. Are you using any attachements plugin?
Greg Drazek August 6, 2019
it is for all users.
We do not use any attachements plugin
Christian Elsner
August 6, 2019
We have the same problem as well. It seems that this behaviour only appears within the chrome browser.
Petr Vaníček
August 6, 2019
I also using Chrome browser without that problem. From which version of Jira 7 did you made upgrade? Maybe that's point of problem.
Also try to clear plugin cache like in that case - don't forgot on backup before that, just in case.
Christian Elsner
August 7, 2019
we made an upgrade from 8.3.0 > 8.3.1. Within the version 8.3.0 we did not have this kind of behaviour. And in our case this problem appears only by using the chrome browser.
Christian
Signe Overå
August 12, 2019
We have the same problem. For all users in all issues. Seems to only be in Chrome - or at least it works fine in IE.
Signe
