I made a Next-Gen Project hoping to take advantage of the customizable form fields in building a short and sweet issue collector form to add to my website. However, when I go to the Project > Project Settings there is no Issue Collector link available as there is in the classic projects outlined in the Using the issue collector (Cloud) documentation.
I went to an Issue Collector in a classic project and obtained a couple of URLs and update the projectKey (see link below) with a Next-Gen key...
https://yourcompany.atlassian.net/secure/ViewCollector!default.jspa?projectKey=XX
https://yourcompany.atlassian.net/secure/AddCollector!default.jspa?projectKey=XX
However, when I setup and click Submit on the Add issue collector page the web page appears to refresh or reload with all field values still present and no redirect to a next step or page confirming success. If I go to View issue collector using the URL above it is not listed for the project, which btw does show a proper breadcrumb trail (see below).
Projects / Next-Gen_Project_XX / Project settings / Issue collectors
So, below are my questions for the Issue Collector (Cloud):
Thanks!
At this point it is not possible to create issue collectors in Next-Gen - although there is a suggestion you can vote for, see JSWCLOUD-17630
Not sure on your question 3 - can you elaborate on what support you're looking for?
There are some other options you could explore - this article has some good suggestions!
Ste
Is there an app for this? For Next Gen
