×I've used the following code to try to validate that there is a certain link type when a custom field has a certain value. It is failing whether I create the link before the transition or when I try to link during the transition. I've used the link name, in inward link name, and the outward link name. Nothing successful. Any suggestions?
if (cfValues['Implementing Standard Fields']?.value == "Yes") { return issueLinkManager.getOutwardLinks(issue.getId())*.issueLinkType.name.contains('Implementation') } else { return true }
Remove the cf validation for the time being and check the linking works. What you have looks correct but for clarity use:
def issueLinkManager = ComponentAccessor.getIssueLinkManager() issueLinkManager.getOutwardLinks(issue.getId()).any { it.issueLinkType.name == 'Implementation' }
If that doesn't work can you post a screenshot of your Issue Linking config page.
That won't work for issues added this transition, for that see https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/validators/simple-scripted-validators.html#_checking_linked_issues.
I have two ideas offhand. The first is, is "Implementation" part of the actual link "Name", or is it just part of the outward/inward link description?
The second thought is, does the custom field portion of the validator work if you return false? As in:
if (cfValues['Implementing Standard Fields']?.value == "Yes") { return false } else { return true }
That's how I normally narrow down the area of failure. What type of custom field is that? If it's not a string field, you may need to compare to a boolean, for example.
I am not sure for groovy sintax, but for Java it should be:
cfValues[
]?.value.equals(
"Yes")
I don't think the if statement is my problem. When I choose, "No" it let's me pass through. It's when I choose yes, that it's not recognizing the issue link.
Ok, second idea: there outward and inward links. Are you sure that you try to get correct one.
Third: issueLinkManager.getOutwardLinks return issue list. I am not sure of groovy sintax, but there should be some loop.
I've tried pretty much every combination of outward and inward
