Issue Movement in Bulk from one project to other in Jira 4.4.3
bobby November 30, 2013
Hi Team,
I want to move multiple issues in bulk from one Project to other project, without losing any data, How I can do the same, I'm using Jira 4.4.3
Thanks in Advance for the help.
Rahul Aich [Nagra]
November 30, 2013
It can be done pretty easily by using the jira bulk change feature.
Have a look at this url for details
https://confluence.atlassian.com/display/JIRA044/Modifying+Multiple+('Bulk')+Issues
rahul
Thanks Rahul, But one more question if in both projects custom fields are different, so while moving the issue from first project to second one field data will be lost how I can save that?
Rahul Aich [Nagra]
November 30, 2013
Custom field data will not be lost , it will just be hidden.
What you need to do first is to check the custom field context and ensure that all those custom fields which were enabled for project A are also enabled on your project B
Second, you need to ensure that the screens that are visible for project B, has those custom fields in them.
If you can ensure above two points, the custom field information will be visible to you after you do the bulk move.
Rahul
bobby December 2, 2013
Thanks Rahul
