Issue Panel Activity - why is activity stream showing stuff not related to issue
Hrvoje Reich May 10, 2018
We have problem in Jira, on most issues in the activity panel  on activity tab - there are listed changes not related to that particular issue..How is that possible...We have stage / production Jira separated, and in the stage Jira it works ok.
Hrvoje Reich May 15, 2018
I am seeing updates in confluence... I also noticed application links and after removing it activities are normal.. Is there a downside effect of removing application links?
Javi
May 15, 2018
It depends if you are linking Jira issues within Confluence pages and vice versa. By removing the application link to Confluence, you are also removing linking functionality.
Here is a link to what functionality is provided by creating an application link between Jira and Confluence
See: Use Jira applications and Confluence together
Javier A.
Javi
May 15, 2018
Hi Hrvoje,
What kind of activity are you seeing? If possible, could you provide screenshot(s) of what you see
Additionally, make sure to check if you have any automation enabled or if any third-party plugins are making any changes to an issue.
Lastly, make sure to see if you have any Application Links created to any other Atlassian Application to ensure that this is not a cause for the activity showing up.
Javier A.
