Hello, I've set accidentally a resolution to default and would like to go back to the previous state. Could someone tell me how to do that ? Thanks in advance. Nicole M.
I've found the solution:
1. Create a temporary resolution,
2. Define it as Default (the Default property is moved from the other resolution to the temporary one).
3. Delete the temporary resolution
Back to the initial configuration: there is not any more default resolution
