I want to add issue templates that will automatically pre-filled with the template when Jira users create an issue. The issue template option isn't appearing under project settings - issues or apps. What is the right location to apply this settings?
Appreciate any feedback, thank you.
do you mean forms? You can create forms with default values for fields. The fields from the form template will then be prefilled if a user creates an issue. Forms are available for jira service management and jira work management.
Regards
Tolga
Hi Lottiah,
Thank you for your interest in Issue Template Pro for Jira - Summary & Description Templates
We made slight changes to the original UI, therefore it looks a bit different now. You can refer to our documentation here: https://help.narva.net/issue-template-for-jira/create-an-issue-template
Let us know if you still have any questions.
Nar
