Hello everyone ,
I have just installed jira version 8.21.0 and created a new project in order to test issue collector. I noticed that on this version the embedded code created for issue collector differs from version 8.5.13 which I used in the past.
JIRA v8.21.0
<!-- Requires jQuery! -->
<script src="https://<my_domain>/plugins/servlet/issueCollectorBootstrap.js?collectorId=4edbe7e4&locale=en_US"></script>
<script>window.ATL_JQ_PAGE_PROPS = {
"triggerFunction": function(showCollectorDialog) {
//Requires that jQuery is available!
jQuery("#myCustomTrigger").click(function(e) {
e.preventDefault();
showCollectorDialog();
}};</script>
For me the above code seems to be unusable.
in the past the embedded code was like below.
JIRA v.8.5.13 (took it from https://confluence.atlassian.com/adminjiraserver/advanced-use-of-the-jira-issue-collector-938847349.html, but is almost the same)
<head>
<script type="text/javascript" src="https://<my_domain>/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-1ygm5v/805001/1b5bd841708e5e0e6309d518d1cf3040/2.2.4.7/_/download/batch/com.atlassian.plugins.jquery:jquery/com.atlassian.plugins.jquery:jquery.js?collectorId=4edbe7e4"></script>
<script type="text/javascript" src="https://<my_domain>/s/6ee0087fdbf8b5d6c068254d3ad5693a-T/-1ygm5v/805001/1b5bd841708e5e0e6309d518d1cf3040/3.1.0/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?locale=en-US&collectorId=4edbe7e4"></script>
<script type="text/javascript">
//Requries that jQuery is available!
jQuery("#feedback-button").click(function(e) {
e.preventDefault();
</script>
</head>
<body>
<h2>Jira Issue Collector Demo</h2>
<a href="#" id="feedback-button" class='btn btn-primary btn-large'>Report feedback</a>
</body>
Do you have any idea idea why this change and in the "src="<my_domain>/s/ " the /s/ stands for what ?
Many thanks in advance.
Is this issue resolved, Did you find the solution for this issue.
Because i'm also facing the same issue. If it is solved, can you please share me the details.
@Katie Chimirri Is this issue resolved, Did you find the solution for this issue.
@Moise Lucian Did you ever resolve this? I am having the same issue. Thanks!
