Issue collector not setting field to required
Josh Kebbel-Wyen February 6, 2015
I'm trying to set up a form in issue collector. I'm running the latest JIRA version. For the life of me, I cannot figure out how to set my questions in my form as required. These are all custom fields and I have already set them as required in my field configuration. What am I missing?
kitkat
February 10, 2015
Can you verify that the custom field that you have set as required in your Field Configuration is also configured for the same Issue Type that the Issue Collector uses (For example, if it's only for Bugs, then your Issue Collector will also need to have Bugs for it's Issue Type)? If they aren't the same, then the field that you made required will not show up. Also, the required field will not appear in the drag and drop area of the Issue Collector configuration, as it will already by listed in the screen sample along with the other default fields.
