Issue key in smart commit resolves to a crucible link
Scott Chang
January 29, 2016
This question is in reference to Atlassian Documentation: Using Smart Commits
Normally developers check in source with comment like:
JIRA-100 text comments...
and when this entire line appears in the source tab, the JIRA-100 portion is a hyperlink to that JIRA-100 issue. However, some projects end up having the JIRA-100 hyperlinked to Crucible (where such review key does not exist) and gets a Crucible page with message "review not found"
Are there project linkage mis-configuration that would cause this?
Fisheye/Crucible 2.10.0, JIRA 5.2.8
thanks,
Scott
Piotr Swiecicki
January 30, 2016
Hi Scott,
Is this possible that you have a Crucible project of "JIRA" key configured in your system?
Scott Chang
February 1, 2016
We did have same project key between JIRA and crucible before but I had since changed the crucible project key to JIRA-CRU and the problem persisted
