Issue linking JIRA with Stash
Nil Plana February 3, 2015
Hi, I'm trying to configure link of JIRA and Stash for test and possible for buy in not much time.
I get an issue when I'm linking these two services:
And then also shows that:
I don't know what is the problem or how to know which problem is it? I tried some different configuration of server.xml of both services. Is there a solution?
RPandyaram
February 3, 2015
There is a mismatch of the base url that is used to configure and what is mentioned in your server.xml probably. please update your base url exactly what is mentioned in your server xml.
Which tag? only I have the url on <Connector tag an attribute is proxyURL. Is it that? Or on <Engine tag?
RPandyaram
February 3, 2015
Please check the context path and here is some helpful stuff: https://confluence.atlassian.com/display/DOC/Configuring+the+Server+Base+URL
Ok, but if I configured with a subdomain? What can I write into path of context?
RPandyaram
February 3, 2015
Hi Nil, If your applications are running behind firewall, dont change the server xml, rather use the same data updated as base url at the applications and try to integrate. This might help. :)
nilpix
February 3, 2015
Thanks for your attention. But I don't understand much what are you saying. Do you mean that use the same port? More information for it helps to solve it. My configuration: jira.mydomain.com under port 8080 and stash.mydomain.com under 7990. Firewall is disabled into my server. And into Context (path="") because I don't know what I must to write inside if I'm working with subdomains. Is it right my configuration? What I'm doing wrong?
CruzinUSA
February 3, 2015
Hi Nil, You'll need to know how your network is set up to really resolve this issue. You shouldn't have to change too much in the server.xml Are you using a proxy or is the url being rewritten at all? The applicationURL must be able to communicate both ways, JIRA is unable to communicate with Stash thus why the application git seems to be online.
I'm using a proxy. In both says the same: "Application git(stash)/jira seems to be offline. Maybe both are unable to communicate. Here server.xml if it helps: http://jsfiddle.net/nilpix/2e664rvy/. The jira server.xml is quite similar.
