Issue migration current project to new project in jira cloud instance.
koteswararao
March 13, 2019
best way you would suggest to take the issue export from current instance and then after creating a project in Jira instance
Shreyance Shaw March 14, 2019
We have been doing quite some migrations within our firm between JIRA instances.
I would recommend a split approach
Use JSON Import to Migrate System Fields (including History)
Use CSV import to migrate custom Fields.
JSON Import would allow you to import history
CSV import would allow you to change custom field values if required.
Alexey Matveev
March 14, 2019
I would suggest to do it by exporting issues to a csv file and then importing this csv file to another instance. But it would require to create manually the project on the destination Cloud and also issue history would not be migrated. But if it is ok with you, it is the easiest way to do it.
To export data go to the Issue Navigator, execute a search (project = yourproject) and use the export button.
Here is how you can import data:
https://confluence.atlassian.com/adminjiracloud/importing-data-from-csv-776636762.html
shetty
March 14, 2019
If it is same Jira Cloud Instance then
Create new project and bulk move all the issues to new project from existing
No need to take export of issues
If You want to migrate from one jira cloud instance to other other Cloud Instance then
Export Issues In Excel CSV Format(all Fields) from existing jira
Import Issues in new Jira instance through External system Import available in jira settings
Note :- You need to be a jira administrator to perform above actions
