I want to create a filter to be used in dashboard for identifying the issues that were created over 180 days ago and are still unresolved. I can do rest of the query need help with the 180 days part
Hello Salman,
Hope you have been fine.
I would use a JQL similar to what Trudy mentioned, but with a small change related to the resolution so we can search for tickets that don't have a value in the resolution field:
created < startofday(-180d) and resolution is EMPTY
I also recommend checking the pretty good documentation below to understand more about resolutions:
Please give it a try and let me know how it goes.
Carlos
created < startofday(-180d) and statusCategory!=Done
I would use resolution is empty instead statusCategory!=Done
Some times with status are used in may WF and the status catagory is not "right" so resolution seems more accurate.
