Hi all,
I have done the upgrade of my Jira from 7.1.2 to 7.6.2, all seems fine but I see that when check all project the priority is not appeared on.
When I associated to or deleted all priority to one project, I have error 500 on GUI and I have below error on logs:
2018-05-16 16:07:08,371 http-nio-8080-exec-18 ERROR jacyntha 967x5829x1 1f93zxw 192.168.101.80,127.0.0.1 /secure/admin/EditPriorityScheme!default.jspa [webwork.util.ValueStack] query="/projectsForScheme" {[id="null" type="5" values=""]} {[id="projectsForScheme" type="8" values=""]}
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
at webwork.util.ValueStack.findValue(ValueStack.java:417)
at webwork.util.ValueStack.findValue(ValueStack.java:216)
at webwork.view.taglib.WebWorkBodyTagSupport.findValue(WebWorkBodyTagSupport.java:62)
Caused by: java.lang.IllegalArgumentException
at com.google.common.base.Preconditions.checkArgument(Preconditions.java:108)
at com.atlassian.jira.issue.fields.config.manager.PrioritySchemeManagerImpl.getProjectsWithScheme(PrioritySchemeManagerImpl.java:304)
at com.atlassian.jira.issue.priority.PrioritySchemeHelperImpl.getProjectsForScheme(PrioritySchemeHelperImpl.java:25)
at com.atlassian.jira.web.action.admin.priorities.EditPriorityScheme.getProjectsForScheme(EditPriorityScheme.java:159)
... 392 more
2018-05-16 16:07:08,377 http-nio-8080-exec-18 WARN jacyntha 967x5829x1 1f93zxw 192.168.101.80,127.0.0.1 /secure/admin/EditPriorityScheme!default.jspa [c.a.j.i.fields.config.FieldConfigSchemeImpl] There is not exactly one config for this scheme (12408). Configs are {}.
2018-05-16 16:07:08,377 http-nio-8080-exec-18 ERROR jacyntha 967x5829x1 1f93zxw 192.168.101.80,127.0.0.1 /secure/admin/EditPriorityScheme!default.jspa [webwork.util.ValueStack] query="/projectsForScheme/size" {[id="null" type="5" values=""]} {[id="projectsForScheme" type="8" values=""]} {[id="size" type="8" values=""]}
... 394 more
2018-05-16 16:07:18,881 http-nio-8080-exec-6 WARN jacyntha 967x5844x1 1f93zxw 192.168.101.80,127.0.0.1 /secure/admin/EditPriorityScheme.jspa [c.a.j.i.fields.config.FieldConfigSchemeImpl] There is not exactly one config for this scheme (12408). Configs are {}.
2018-05-16 16:07:18,882 http-nio-8080-exec-6 ERROR [o.a.c.c.C.[.[localhost].[/lynx].[action]] Servlet.service() for servlet [action] in context with path [/lynx] threw exception [java.lang.NullPointerException: config] with root cause
at java.util.Objects.requireNonNull(Objects.java:228)
at com.atlassian.jira.issue.fields.option.CachedOptionSetManager.updateOptionSet(CachedOptionSetManager.java:60)
at com.atlassian.jira.issue.fields.config.manager.PrioritySchemeManagerImpl.updateWithDefaultMapping(PrioritySchemeManagerImpl.java:198)
at com.atlassian.jira.issue.fields.config.DefaultPrioritySchemeService.editScheme(DefaultPrioritySchemeService.java:170)
at com.atlassian.jira.web.action.admin.priorities.EditPriorityScheme.doExecute(EditPriorityScheme.java:104)
... 1 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
... 48 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:62)
... 12 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 62 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
Can you help me to resolve it please?
Kindly,
Jacyntha
Hi all,
Can I have feedback please because I can't go forward on this.
Kindly,
Jacyntha
HI all,
Can you update please?
Kindly,
Jacyntha
