Issue remain opened although marked as DONE and Resolved
Vital Kravitz January 25, 2023
we're manually switching issue statuses,
when trying to "complete" a sprint - the prompt message says;
"the sprint contains open issues"
we didn't encounter this problem before, and we can't figure out what we did to cause this issue.
has anyone successfully dealt with this?
John Funk
Hi Vital - Welcome to the Atlassian Community!
Are you sure the issue is in the last column on the board? Are there any open Sub-tasks under the issue?
Vital Kravitz January 26, 2023
nope, i've verified all possible options.
my solution has indeed solved this issue for us.
John Funk
What was your solution?
***resolved***
I've set the "APPROVED" column as the left-most column
(in project settings > columns and statuses)
John Funk
Right - perfect!
Like Vital Kravitz likes this
sekhar reddy
January 26, 2023
Hi @Vital Kravitz
Did you checked the resolution of the Issue?, try query the sprint issues and check the issue that has been open resolution.
i did,
***resolved***
sekhar reddy
January 26, 2023
Search the sprint Issues in JQL and find the Issue which is not completed.
