Issue tracker - createdDate plus x days
Remon Vrij September 12, 2013
I'm trying to make a search which does the following:
Shows me issues of:
1. A specfic issue type.
2. A specific priority.
3. Who's creation date is equal or bigger then it's creation date + 10 days.
issuetype = //TYPEHERE AND priority = //PRIORITYHERE AND createdDate >= createdDate (+10)
As you have figured out by now the last part breaks "createdDate (+10)".
Can anyone help me in the rigth direction on this?
Remon Vrij September 29, 2013
issuetype = //TYPEHERE AND priority = //PRIORITYHERE AND createdDate<= -240h
Jason Plumhoff
September 13, 2013
Wouldn't createdDate ALWAYS be less than createdDate + 10?
Remon Vrij September 15, 2013
My expectation:
Issue is created on the 10th making createdDate 10, now it should show in this filter if the current date is 20 because that would be createdDate +10.
Hope that made sense for you.
