Issue trying integrate Okta with our JIRA
Marco Parra December 17, 2014
We are trying to set JIRA to use SSO via Okta, we configured with the data provided by our Okta's admin, and now we are getting this error:
Oops - an error has occurred
System Error
A system error has occurred.
If this problem persists, please contact your JIRA administrators.
Otherwise, please create a support issue on our support system at http://support.atlassian.com with the following information:
  1. a description of your problem
  2. cut & paste the error and system information found below
Cause
Referer URL: https://mycompany.okta.com/app/jira_onprem/kzxbiqlmEZFGKYMYLNXW/sso/saml
java.lang.NullPointerException
Hide stack trace
at com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator.getUserFromSession(OktaJiraAuthenticator.java:330)
at com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator.getUser(OktaJiraAuthenticator.java:142)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:132)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:74)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:203)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:181)
at net.bull.javamelody.PluginMonitoringFilter.doFilter(PluginMonitoringFilter.java:86)
at net.bull.javamelody.JiraMonitoringFilter.doFilter(JiraMonitoringFilter.java:95)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:84)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:74)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:581)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Build Information
Uptime N/A
Version 6.0.8
Build Number 6109
Build Date Wed Aug 28 00:00:00 EDT 2013
Build Revision 57cf0994e68656877c0b65494d19956a638f4633
Atlassian Partner null
Installation Type Standalone
Server ID Contact your Administrator to discover this property value.
Last Upgrade Jun 06, 2013 03:22 PM (v5.2.7#850)
Server Information
Application Server Apache Tomcat/7.0.29
Servlet Version 3.0
File Paths
Contact your System Administrator to discover file path information.
Do you know what we are doing wrong?
Thank you in advance,
Regards.
SrinivasC April 2, 2015
Hi Marc or Nick,
The instruction don't say clearly as to where to save this okta-config-jira.xml (whether in to lib folder or classes folder).. all it says at one point is on "save it on JIRA server" and another point " save in to <okta-directory-on-Jira-server>, for examaple /opt/okta.
What is this <okta-directory-on-Jira-server>??? The document doesn't say any thing about this directory.
It is very frustrating to follow it. Can one of you kindly get back to me?
Srini
schimata2@gmail.com
Adeel Hussain Qureshi
July 26, 2017
I am also able to resolve it by providing full address of xml
<authenticator class="com.atlassian.confluence.authenticator.okta.OktaConfluenceAuthenticator">
<init-param>
<param-name>okta.config.file</param-name>
<param-value>/opt/atlassian/confluence/confluence/WEB-INF/classes/okta-config-confluence.xml</param-value>
</init-param>
</authenticator>
Marco Parra April 23, 2015
Hi Srini,
sorry for the delay, you should put the okta-config-jira.xml file on your Catalina's JIRA home folder.
You could get this value on your JIRA's site:
https://yours-jira-site-running.com/secure/admin/ViewSystemInfo.jspa
on side the of JVM Input Arguments, you should see something like this:
.... -Dcatalina.home=JIRA_PATH -D morejava values.............
so, you must put your config file on:
JIRA_PATH\atlassian-jira\
for my case:
-Dcatalina.home=D:\JIRA_Application\jira.mycompany.com
so I put my okta-config-jira.xml at D:\JIRA_Application\jira.mycompany.com\atlassian-jira\ folder.
I hope helps you.
Regards.
P.S.: don't forget restart your JIRA instance.
Daniel Kuźba
July 4, 2017
Thank You.
Nic Brough -Adaptavist-
December 17, 2014
There's a bug in the Okta authorisation addon, or your configuration is wrong.
I'd start by going over https://support.okta.com/entries/29583593-Using-the-Jira-On-Premises-SAML-App and making sure you have followed the instructions exactly.
Thank you, I was able to solve this issue, I moved the okta-config-jira.xml to another folder, and restarted JIRA, and that's worked for us. Thank you.
Srini Chimata NNA April 1, 2015
Hi Marco, I want to do the Okta-Jira integration in my company. Can you kindly point me to the documentation links as to how I get started? Currently, we have the "LDAP Sync" User Directory setp in our prod Jira. Thanks, Srini schimata2@gmail.com
