The cause of the problem was found to be Script Runners Script Field. I have a field that renders some HTML to show an image in the Issue View. For some reason this causes the error.
I currently have no solution to the problem, but the cause is understood.
See here for new, specific, question: https://answers.atlassian.com/questions/17903735
Try a "forced" reload of the page. If on windows, hold Ctrl and hit F5. If on OSX, hold Command, then Shift, then press R.
Hi Mike,
Does this issue happen on a specific browser or is reproducible when accessing from different browsers, such Chrome, Firefox or IE? If this is restricted to a single browser or computer, please try clearing the cache or accessing from another computer.
As a test, you can also try to access JIRA using a private session on your web browser and attempt to reproduce the problem.
If you still facing problems after the tests mentioned above, we recommend you to log a ticket into Atlassian Support.
-- Arthur Gonçalves
What do you mean by "Private Session"?
Something like this: https://support.google.com/chrome/answer/95464?hl=en :)
