I am try to query teams using the TeamSearchV2 with the following query:
query Team($orgId: ID!, $siteId: String!,$query: String!)
{ team
{ teamSearchV2(organizationId: $orgId, siteId: $siteId, filter: {query: $query}, searchFields:[NAME])
{ edges
{ node {
memberCount
includesYou
team {
displayName
description
id
state
If I remove the searchFields:[NAME] from the query its works fine. With it I get the following error:
"message": "Validation error (UnknownType) : Unknown type 'TeamSearchField'",
Any ideas or suggestions?
Thanks in advance
Hello @Dante Shareiff
The error you’re encountering appears to be related to the use of the searchFields:[NAME] parameter. Based on my understanding, the error suggests that the TeamSearchField type isn’t recognized in your GraphQL schema.
Double-check the schema documentation to ensure that NAME is a valid search field for TeamSearchV2. If it’s not explicitly supported, removing the searchFields parameter, as you mentioned, is a temporary solution.
If you still encounter issues, reach out to Atlassian support at https://support.atlassian.com/contact/#/.
May I suggest reading the documentation before answering the question ?
https://developer.atlassian.com/platform/atlassian-graphql-api/graphql/#teams_teamSearchV2
