An issue was deleted unfortunately, is there a way to restore them. ?
Hi from front end, it's impossible.
Do you have daily backups, if yes create a test instance and restore XML file - Atlassian - application data - Export
Here you can find backups, restore the latest backup which is before the issue deletion, into your test environment.
This process may helpful a bit
Kagithala Babu Anvesh
