I am trying to search for tests of a particular component and trying to save the filter, but its not working. Could someone point me to the required syntax.
I went to the search issues page and did: (issuetype=Test and "Automation Status"="Fully Automated").
Here automation status is a custom field which has one of the values as Fully Automated
If "Automation Status" is a custom field of type Text you need to use following syntax (with contains operator)
issuetype=Test and "Automation Status"~"Fully Automated"
Have you tried
issuetype=Test and "Automation Status" in ("Fully Automated")
Whether the custom fields Apply to issues special projects
Try to increase in the query like issuetype=Test and "Automation Status"="Fully Automated" and project = xxxx
Even that is not working, so basically I have tried searching in 3 places 1. the search test page [project = 10000 and issuetype = 10000 and "Automation Status"="Fully Automated"] 2. In a particular test cycle in a version: Here searching is not possible as custom fields are not showing up in the columns. 3. Search issues page. None of them is working I read somewhere that querying on custom fields is not possible, is that true?
Could you tell me the value of this field is manually choose, or according to the process to determine automatic filling?
