Issue with JIRA 6.1 conditions in workflows
Adolfo Casari
November 20, 2013
In Jira 6.1 there is a new design to define conditions/grouped conditions in workflows. However, the condition is always shown as "All of the following conditions" (the other option being "Any of the following conditions"). When you edit the workflow it will show the correct setting though.
Has this been filed as a bug?
Thanks in advance,
Adolfo Casari
January 28, 2014
This was fixed in version 6.1.5
Ruchi Tandon
March 18, 2014
I guess we are all talking about this bug : https://jira.atlassian.com/browse/JRA-34880
LL January 27, 2014
I've also seen this very same error. Huge pain.
RambanamP
November 21, 2013
yes, you are correct!! i am also seen same behaviour,
i suggest you to submit bug with atlassian @
https://jira.atlassian.com/secure/Dashboard.jspa
Nic Brough -Adaptavist-
November 20, 2013
Look to the right hand side of the list of conditions for a two-pronged fork - when you hover over it, you should see "add grouped condition". That lets you do the old A and (B or C) thing.
Adolfo Casari
November 21, 2013
That's not the issue. It's allways displaying All of the following conditions even when you marked Any of the following conditions for a group(s).
November 21, 2013
I don't see that on the 6.1 I'm looking at, it shows the currently selected setting above the list of conditions.
I'd raise the issue with Atlassian.
