×Hi guys - I was wondering if you guys have seen this issue before::
I've recently rebooted my Jira 6 installation after upgrading Script Runner to 2.1.12, it was all working fine for a few days, then we rebooted the physical server - and since then, Script Runner won't start up at all. We've changed the searchers for all 6 custom fields and switched then between the natural text searcher and free text searcher, but it looks like it's failing before it even gets to that point.
Any thoughts on what could be causing this in Jira 6.0.6?
2013-09-20 05:55:02,529 Thread-33 WARN [onresolve.jira.groovy.ScriptManagerImpl] Failed to create searcher custom field. Can happen during upgrades. com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149) at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) at com.atlassian.util.concurrent.ResettableLazyReference.get(ResettableLazyReference.java:87) at com.atlassian.jira.issue.fields.CustomFieldImpl.getCustomFieldSearcher(CustomFieldImpl.java:1807) at com.atlassian.jira.issue.fields.CustomFieldImpl.<init>(CustomFieldImpl.java:249) at com.atlassian.jira.issue.fields.CustomFieldImpl.<init>(CustomFieldImpl.java:222) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager$CustomFieldCache.cloneCustomFields(DefaultCustomFieldManager.java:730) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager$CustomFieldCache.getAllCustomFields(DefaultCustomFieldManager.java:717) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager$CopyOnWriteCustomFieldCache.getAllCustomFields(DefaultCustomFieldManager.java:621) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getAllCustomFields(DefaultCustomFieldManager.java:417) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getCustomFieldObjects(DefaultCustomFieldManager.java:412) at com.atlassian.jira.issue.CustomFieldManager$getCustomFieldObjects.call(Unknown Source) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112) at com.onresolve.jira.groovy.ScriptManagerImpl.createIndexingCustomField(ScriptManagerImpl.groovy:500) <+3> at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1054) at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnCurrentN(ScriptBytecodeAdapter.java:78) at com.onresolve.jira.groovy.ScriptManagerImpl.this$dist$invoke$1(ScriptManagerImpl.groovy) at com.onresolve.jira.groovy.ScriptManagerImpl$1.methodMissing(ScriptManagerImpl.groovy) <+3> at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaClassImpl.invokeMissingMethod(MetaClassImpl.java:811) at groovy.lang.MetaClassImpl.invokePropertyOrMissing(MetaClassImpl.java:1103) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1056) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:884) at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:137) at com.onresolve.jira.groovy.ScriptManagerImpl$1.run(ScriptManagerImpl.groovy:395) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.NullPointerException at com.atlassian.jira.util.JiraUtils.loadComponent(JiraUtils.java:96) at com.atlassian.jira.util.JiraUtils.loadComponent(JiraUtils.java:91) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.loadSearcher(DefaultCustomFieldManager.java:286) at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getCustomFieldSearcher(DefaultCustomFieldManager.java:273) at com.atlassian.jira.issue.fields.CustomFieldImpl$CustomFieldSearcherLazyRef.create(CustomFieldImpl.java:2101) at com.atlassian.util.concurrent.ResettableLazyReference$InternalReference.create(ResettableLazyReference.java:140) at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:321) at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143) ... 40 more 2013-09-20 05:55:03,013 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:00:39.361 2013-09-20 05:55:03,029 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
Best regards,
Scott
Disabled natural text searchers and uninstalled script runner.
Restarted, then installed 2.14, which installed successfully and started up - at which point I re-enabled natural text searchers.
For some reason wouldn't work when both were installed
Have logged GRV-338, as I don't think it's related to upgrading jira so much.
Hi Scott,
The logfile says: Failed to create searcher custom field, but unfortunally not which field causes the error.
I think the problem results from Zephyr's customfield (Teststep Field Typ)
The fields textsearcher was initially set to nothing. As a textseracher you can choose between nothing and the Zephyre searcher.
I tried a lot (SR 2.14, and I disabled the Zephyr) but got no solution. At least I deinstalled the script runner.
Hi the first link is a previous version, which is throwing quite a different error.
It was actually fine after an upgrade, it was only after restarting that it went completely wrong.
Currently the plugin is actually required for all of our workflows - removing and reinstalling doesn't work. Hopefully Jamie is aware of this issue.
