Issue with copying tables from Jira to Azure data lake using API token in Azure data factory
Himanshu Rathi April 17, 2023
I am experiencing a similar issue with my pipeline in Azure. My pipeline is set up to transfer data from Jira to the data lake, and I have used an API token to establish the connection.
However, I am encountering a problem where only one table gets copied successfully while others are not. I have tried using a for loop and a single copy activity, but the other tables are not being copied at all. I have attached some screenshots for reference.
Have any of you encountered this issue before? I would greatly appreciate any insights or advice on how to resolve this.
@sudhir kumar rai  @Nic Brough -Adaptavist- @Prateek Fulsundar @Brant Schroeder @Peter Preston @Andrew Daniels  I would appreciate any assistance if you can provide it.
