Issue with using RSAL Saml with SSO
Dustin Peterson
February 4, 2020
Keep getting this message trying to use saml.  I've entered the entity Id url but keep getting this error.
Hmm... we're having trouble logging you in. You'll need to talk to your organization admin - tell them we sent you, and that there appears to be an issue with the identity provider entity ID used for your SAML single sign-on configuration.
Not sure what we're missing
Ed Letifov _TechTime - New Zealand_
February 4, 2020
Can you at least provide an anonymised URL?
Dustin Peterson
February 5, 2020
This is our Identity provider that contains the Entity ID
https://portal.sso.raleys.com/IdPServlet?idp_id=jx11hg2mpec7
This is the base url for our sso solution.  https://portal.sso.raleys.com
February 6, 2020
Can only suggest to raise this with Atlassian Support for Atlassian Cloud (and specifically Access): https://support.atlassian.com/products/
