IssueEventDispatcher problem
gil
I dispatch an event like this: IssueEventDispatcher.dispatchEvent(eventID, issue, user) but receive the following error the the log. What's wrong?
2011-11-20 11:12:20,000 http-1111-1 ERROR xxx 111x11x1 xxxx xxx /secure/EditIssue.jspa [atlassian.event.internal.EventPublisherImpl] There was an exception thrown trying to dispatch event 'com.atlassian.jira.event.issue.IssueEvent@xxx[issue=xxx-111,comment=<null>,worklog=<null>,changelog=<null>,eventTypeId=10001,sendMail=true,params={baseurl=http://localhost},subtasksUpdated=false]' from the invoker 'com.atlassian.event.internal.SingleParameterMethodListenerInvoker@xxxx'.
java.lang.RuntimeException: java.lang.StackOverflowError
gil
The stackoverflows remain. See the modified code along with the error below:
@EventListener
public void onIssueEvent(IssueEvent issueEvent) {
Long eventTypeId = issueEvent.getEventTypeId();
Issue issue = issueEvent.getIssue();
Project p = issue.getProjectObject();
if(p.getKey().equals("TST"))
try
if (!eventTypeId.equals(10001))
IssueEventDispatcher.dispatchEvent((long) 10001, issue, null, false);
catch (Exception e)
System.err.println("Error:");
2011-11-21 10:56:53,355 http-8111-3 ERROR admin 656x22x1 18pc2nf 165.253.44.125,127.0.0.1 /secure/EditIssue.jspa [atlassian.event.internal.EventPublisherImpl] There was an exception thrown trying to dispatch event 'com.atlassian.jira.event.issue.IssueEvent@31a0a62a[issue=TST-1905,comment=<null>,worklog=<null>,changelog=<null>,eventTypeId=10001,sendMail=false,params={baseurl=http://jira-stage},subtasksUpdated=false]' from the invoker 'com.atlassian.event.internal.SingleParameterMethodListenerInvoker@124ece1d'.
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:50)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$2.run(AsynchronousAbleEventDispatcher.java:60)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$1.execute(AsynchronousAbleEventDispatcher.java:28)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:56)
at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:151)
at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:70)
at com.atlassian.jira.event.issue.IssueEventDispatcher.dispatchEvent(IssueEventDispatcher.java:126)
at com.atlassian.jira.event.issue.IssueEventDispatcher.dispatchEvent(IssueEventDispatcher.java:57)
at com.atlassian.jira.event.issue.IssueEventDispatcher.dispatchEvent(IssueEventDispatcher.java:41)
at com.example.tutorial.plugins.IssueCreatedResolvedListener.onIssueEvent(IssueCreatedResolvedListener.java:82)
at sun.reflect.GeneratedMethodAccessor200.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:36)
Caused by: java.lang.StackOverflowError
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:1850)
at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:890)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1354)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1233)
at com.atlassian.jira.event.issue.IssueEvent.toString(IssueEvent.java:172)
at java.lang.String.valueOf(String.java:2826)
at java.lang.StringBuilder.append(StringBuilder.java:115)
at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:155)
MattS
November 29, 2011
onIssueEvent is called with an event id and an issue (which could be null?).
You want to fire a new event with id 10001 but it looks like you're getting stuck in a loop. This is likely happening because for some reason the condition
is evaluating true. I'd start by adding a log object and logging the value of the eventTypeId in each pass. Also, I'd probably not rely on the long cast for the required Long object.
MattS
November 29, 2011
gil
So my code look as follows. Basically, when there's a change to a ticket of project TST, I want to fire a custom event which ID is 10001. I don't understand how it goes into an endless loop?
@EventListener
try
IssueEventDispatcher.dispatchEvent((long) 10001, issue, null);
catch (Exception e)
System.err.println("Error!");
Jobin Kuruvilla [Adaptavist]
November 20, 2011
This will surely result in endless loop. onIssueEvent will be thrown fo all events including your custom event. And the code will be executed for all events including the new event thrown!
You might want to dispatch the new event only when the eventId is not 10001.
Andy Brook [Plugin People]
November 20, 2011
StackOverflow involves a high degree of method calling which can happen with Recursion, or as I expect in this case, an unaticipated linkage between your event generation, another listener processing that event and regeneraton of another event back in your code. Just a thought.
November 20, 2011
Looks like it is going in an infinite loop. You are throwing the event, catching it and throwing it again? Maybe it loops infinitely.
