Issues after upgrading to jira 5.0.2
Alok kumar Singh
We have upgraded to jira 5.0.2 from 4.4.3. After upgradation when I click on any project it shows a blank page. In the logs I am getting this error.
[atlassian.plugin.web.DefaultWebInterfaceManager] Could not evaluate condition 'com.spartez.jira.plugins.jpp.conditions.LicenseIsValidCondition@6062722' for descriptor: com.spartez.jira.plugins.jiraplanningpoker:add-to-pokersession (null)
java.lang.AbstractMethodError
parthiban subramaniam
May 20, 2012
This plugin might be out of date
https://plugins.atlassian.com/plugins/com.spartez.jira.plugins.jiraplanningpoker
remove the non compatible one from jira.home/plugins/installed-plugins and install compatible version and restart and see if it helps
May 20, 2012
oops, OnDemand .. i dont know anything about it .. get in touch with support plz
Ramiro P
May 20, 2012
Woah... Sincerely Alok, you should review all your questions. Your Accept Rate it's kind of... let's say 'Low'
Ramiro P
May 20, 2012
Wait, I might be totally out of place but how you upgraded your Jira version if you are OnDemand, isn't that a thing that Atlassian do?
My guess? Is that you are on Download version and there are a few plugins that have not been updated.
Could this be the reason?
Thomas Schlegel
then, try to disable or update your plugins.
Alok kumar Singh
sorry every one I often gets confused with this tag.....this is the same situation I am getting.
https://answers.atlassian.com/questions/43753/browse-project-screen-is-blank?sort=newest
Ramiro P
May 20, 2012
Good, so it should be a plugin. Could you try what Thomas said?
Alok kumar Singh
thanks everyone...it worked..:-)
Ramiro P
May 20, 2012
Glad it worked Alok! Remember to mark answers as correct.
Cheers!
