Issues appearing in Project but not in Agile Backlog
usamashakeel January 4, 2015
I have added issues to a project and also tried moving from other projects, but they are not becoming part of Agile board.
Is there anything I am doing wrong?
Usama Bin Shakeel
Nic Brough -Adaptavist-
January 5, 2015
To appear on the board, they need to match the filter criteria for the board, in several ways.
Go to board -> Configure and check the first configuration page to see exactly what the board filter is.  Do these issues match it?  Specifically, if you run the filter in the issue navigator, do they appear there?
Next, check that your board includes all status (i.e. on "columns" there are no status that might be containing these issues on the left - they're all under columns).  Check that no "quick filters" are applied too.
Chris Solgat
January 5, 2015
Additionally, if the board in question is a kanban board, the Work Sub-Filter should be checked as well. That was an easy thing to look past when you are setting up your first few boards.
usamashakeel January 5, 2015
Thanks for your replies, Yes filter got it fixed. So renaming a project is something which needs manual fixes to filters. If someone else is upto same mistake :)
