×Hi, I have changed the status of 4 stories/issues to 'In Review' and now they are not visible in current sprint or in backlog
Hi Lohit
You need to go to Board settings by clicking on the three dots in the top right hand corner. Then select the Columns tab and look in the right hand section. There shouldn't really be any "Unmapped statuses" there. I'm assuming that "In Review" may be there - it needs to be dragged and dropped into one of the columns.
It worked, Thank you.
