Issues> Manage Filters> Edit Filter dialog - is blank
Nigel Aston May 12, 2022
Jira v8.22.1
When editing a filter all the options are blank and unable to make any changes.
This is a filter created by me.
So I cannot change it from e.g. Private to public.
All I can do is modify its description.
This used to work in an earlier version of JIRAEdit Filter Dialog - blank.png
Tad Foster
June 14, 2022
This bug is described in:
  • JRASERVER-73361. We have internally linked this ticket to the bug.
    The bug is already fixed in version 8.22.4
Workaround
As a workaround, you can follow one of the below steps to carry through your tasks.
Option 1
  • Click on Issues > Manage filters
  • Search for the filter you want to edit
  • Click on the gear icon and open the Edit option it in a separate tab  (Hold the Ctrl key (PC) or Cmd key (Apple) when clicking Edit)
  • Proceed with the edit
Option 2
  • Open the link for filter in a new tab
  • click on Details > Edit Permissions
Option 3
Use the following URL to edit filter:
http://<hostname>:<port>/secure/EditFilter!default.jspa?filterId=<filter_id>
Retrieve the <filter_id> from Jira database and afterward replace it in the URL:
select * from searchrequest;
Nigel Aston June 13, 2022
The solution we are now using is to bring up the filter, then select 'Details' menu next to 'Save As' at top left; then change permissions within the details dialog.
Nigel Aston May 13, 2022
I wondered if it might be something to do with AdBlocker. I've enabled msot things now, made no difference. In G'Chrome and in M'Edge.
Tad Foster
June 13, 2022
We are seeing the same issue in DC v8.22.2. I'm reporting to it to Premier Support and will be back to follow up.
Like Mark Collins likes this
